Ga door naar hoofdinhoud
Ridgid Circular Saw R3205 Lower Blade Guard Replacement
Wat je nodig hebt
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: stap 1, afbeelding 1 van 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: stap 1, afbeelding 2 van 2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 2, afbeelding 1 van 1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 3, afbeelding 1 van 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 3, afbeelding 2 van 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 3, afbeelding 3 van 3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: stap 4, afbeelding 1 van 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: stap 4, afbeelding 2 van 2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 5, afbeelding 1 van 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 5, afbeelding 2 van 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 5, afbeelding 3 van 3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 6, afbeelding 1 van 1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 7, afbeelding 1 van 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: stap 7, afbeelding 2 van 2
    • Remove the lower blade guard after removing the washer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joshua Caron
792 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Julie Spring 2019 Lid van UMass Dartmouth, Team S5-G2, Julie Spring 2019
UMASSD-JULIE-S19S5G2
5 Leden
Één opmerking
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 2,022
