Ga door naar hoofdinhoud
Ridgid Angle Grinder R10202 Motor Housing Replacement
Wat je nodig hebt
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: stap 1, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: stap 1, afbeelding 2 van 2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 2, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 2, afbeelding 2 van 2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: stap 3, afbeelding 1 van 1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 5, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 5, afbeelding 2 van 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 6, afbeelding 1 van 1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 7, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 7, afbeelding 2 van 2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 8, afbeelding 1 van 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 8, afbeelding 2 van 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: stap 8, afbeelding 3 van 3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 838
