Ga door naar hoofdinhoud
Ridgid Angle Grinder R10202 Disk Guard Spring Replacement
Wat je nodig hebt
  1. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement, Disk Guard Spring: stap 1, afbeelding 1 van 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  2. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 2, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 2, afbeelding 2 van 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  3. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 3, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the 5 M5 X 10mm screws using a Torx T20 Bit.
    • Carefully separate the spacer from the guard.
  4. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 4, afbeelding 1 van 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: stap 4, afbeelding 2 van 2
    • Gently push the spring away from the spacer.
    • The spacer, spring, and guard lever should now be all separate.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 747
