Ga door naar hoofdinhoud
Ricoh YF-20 Super Lens Replacement
Wat je nodig hebt
  1. Ricoh YF-20 Super Lens Replacement, Front Cover: stap 1, afbeelding 1 van 2 Ricoh YF-20 Super Lens Replacement, Front Cover: stap 1, afbeelding 2 van 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Replacement: stap 2, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement: stap 2, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement: stap 2, afbeelding 3 van 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Replacement: stap 3, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement: stap 3, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement: stap 3, afbeelding 3 van 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Replacement: stap 4, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement: stap 4, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement: stap 4, afbeelding 3 van 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Replacement: stap 5, afbeelding 1 van 2 Ricoh YF-20 Super Lens Replacement: stap 5, afbeelding 2 van 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Replacement: stap 6, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement: stap 6, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement: stap 6, afbeelding 3 van 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Replacement, Lens: stap 7, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement, Lens: stap 7, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement, Lens: stap 7, afbeelding 3 van 3
    • The lens is only attached to the main camera body. Set the front and back covers aside.
    • Unscrew three screws from the outermost plastic plate covering the lens.
    • After the screws are removed, the outermost plate can be removed.
  8. Ricoh YF-20 Super Lens Replacement: stap 8, afbeelding 1 van 3 Ricoh YF-20 Super Lens Replacement: stap 8, afbeelding 2 van 3 Ricoh YF-20 Super Lens Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the ring shaped metal brace.
    • Using fingers or tweezers, remove the lens from the camera.
Conclusie
Eric Dazet
352 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-21, Amido Spring 2012 Lid van Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 866
