Ga door naar hoofdinhoud
Ricoh YF-20 Super Lens Cover Replacement
Wat je nodig hebt
    1. Ricoh YF-20 Super Lens Cover Replacement, Front Cover: stap 1, afbeelding 1 van 2 Ricoh YF-20 Super Lens Cover Replacement, Front Cover: stap 1, afbeelding 2 van 2
      • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Ricoh YF-20 Super Lens Cover Replacement: stap 2, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 2, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 2, afbeelding 3 van 3
      • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
      • The lid of the battery compartment may fall off because it is not attached to anything.
      Vraag FixBot
      Voeg opmerking toe
    3. Ricoh YF-20 Super Lens Cover Replacement: stap 3, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 3, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 3, afbeelding 3 van 3
      • Open the film compartment.
      • Press your finger on top of the grey latch on the left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Ricoh YF-20 Super Lens Cover Replacement: stap 4, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 4, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 4, afbeelding 3 van 3
      • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
      • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
      • Use your fingers to completely remove the metal pin.
      • Remove the film compartment door.
      Vraag FixBot
      Voeg opmerking toe
    5. Ricoh YF-20 Super Lens Cover Replacement: stap 5, afbeelding 1 van 2 Ricoh YF-20 Super Lens Cover Replacement: stap 5, afbeelding 2 van 2
      • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
      Vraag FixBot
      Voeg opmerking toe
    6. Ricoh YF-20 Super Lens Cover Replacement: stap 6, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 6, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 6, afbeelding 3 van 3
      • Loosen the front cover from the left and right sides of the camera.
      • Take off the front cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: stap 7, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: stap 7, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: stap 7, afbeelding 3 van 3
      • The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
      • In order to reach the lens cover, the zoom mechanism must be removed.
      • Unscrew three screws from the front cover that hold the zoom mechanism in place.
      • Remove the zoom mechanism.
      Vraag FixBot
      Voeg opmerking toe
    2. Ricoh YF-20 Super Lens Cover Replacement: stap 8, afbeelding 1 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 8, afbeelding 2 van 3 Ricoh YF-20 Super Lens Cover Replacement: stap 8, afbeelding 3 van 3
      • Unscrew the five screws that hold the lens cover plate and metal brace in place.
      • Remove metal brace.
      • Remove lens cover plate.
      Vraag FixBot
      Voeg opmerking toe
    3. Ricoh YF-20 Super Lens Cover Replacement: stap 9, afbeelding 1 van 2 Ricoh YF-20 Super Lens Cover Replacement: stap 9, afbeelding 2 van 2
      • To remove lens cover, push the lens cover from the outside of the front cover towards the inside of the front cover.
      • Remove the lens cover.
      • The metal arm attached to the lens cover is not securely attached and may fall off.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Eric Dazet
352 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-21, Amido Spring 2012 Lid van Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Leden
108 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 53
Altijd: 887
