Ga door naar hoofdinhoud
Ricoh YF-20 Super Front Cover Replacement
Wat je nodig hebt
    1. Ricoh YF-20 Super Front Cover Replacement, Front Cover: stap 1, afbeelding 1 van 2 Ricoh YF-20 Super Front Cover Replacement, Front Cover: stap 1, afbeelding 2 van 2
      • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Ricoh YF-20 Super Front Cover Replacement: stap 2, afbeelding 1 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 2, afbeelding 2 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 2, afbeelding 3 van 3
      • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
      • The lid of the battery compartment may fall off because it is not attached to anything.
      Vraag FixBot
      Voeg opmerking toe
    3. Ricoh YF-20 Super Front Cover Replacement: stap 3, afbeelding 1 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 3, afbeelding 2 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 3, afbeelding 3 van 3
      • Open the film compartment.
      • Press your finger on top of the grey latch on the left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Ricoh YF-20 Super Front Cover Replacement: stap 4, afbeelding 1 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 4, afbeelding 2 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 4, afbeelding 3 van 3
      • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
      • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
      • Use your fingers to completely remove the metal pin.
      • Remove the film compartment door.
      Vraag FixBot
      Voeg opmerking toe
    5. Ricoh YF-20 Super Front Cover Replacement: stap 5, afbeelding 1 van 2 Ricoh YF-20 Super Front Cover Replacement: stap 5, afbeelding 2 van 2
      • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
      Vraag FixBot
      Voeg opmerking toe
    6. Ricoh YF-20 Super Front Cover Replacement: stap 6, afbeelding 1 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 6, afbeelding 2 van 3 Ricoh YF-20 Super Front Cover Replacement: stap 6, afbeelding 3 van 3
      • Loosen the front cover from the left and right sides of the camera.
      • Take off the front cover.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eric Dazet
352 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-21, Amido Spring 2012 Lid van Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Leden
108 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 47
Altijd: 1,145
