Ga door naar hoofdinhoud
Ricoh Theta S Outer Case Replacement
Wat je nodig hebt
  1. Ricoh Theta S Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: stap 2, afbeelding 1 van 2 Ricoh Theta S Outer Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: stap 3, afbeelding 1 van 3 Ricoh Theta S Outer Case Replacement: stap 3, afbeelding 2 van 3 Ricoh Theta S Outer Case Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Conclusie
Bradley Sutton
737 Reputatie
4 handleidingen geschreven
IUPUI, Team S3-G1, Harley Fall 2017 Lid van IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Leden
Één opmerking
Where can find spare part case?
Thanks
Franco - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 2,110
