Inleiding
This is a detailed guide on how to remove the film cartridge door of a Ricoh Super 8 800z camera. This may be necessary if the door is damaged/cracked in some way, or the seal is allowing light in which affects the film. If light leaks are appearing in photos, this guide may be for you. This is a fairly easy process and only requires a screwdriver.
Wat je nodig hebt
Pull the film cartridge door release lever towards the eyepiece to open the film cartridge door.
