Ga door naar hoofdinhoud
Revlon RVDR5061 Heating Element Assembly Replacement
Wat je nodig hebt
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: stap 1, afbeelding 1 van 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: stap 2, afbeelding 1 van 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: stap 3, afbeelding 1 van 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: stap 4, afbeelding 1 van 3 Revlon RVDR5061 Heating Element Assembly Replacement: stap 4, afbeelding 2 van 3 Revlon RVDR5061 Heating Element Assembly Replacement: stap 4, afbeelding 3 van 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: stap 5, afbeelding 1 van 2 Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: stap 5, afbeelding 2 van 2
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: stap 6, afbeelding 1 van 3 Revlon RVDR5061 Heating Element Assembly Replacement: stap 6, afbeelding 2 van 3 Revlon RVDR5061 Heating Element Assembly Replacement: stap 6, afbeelding 3 van 3
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: stap 7, afbeelding 1 van 1
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
Conclusie
Soneil Pitamber
97 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G2, Wilson Summer 2018 Lid van IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 761
