Ga door naar hoofdinhoud
Revlon 473 Heating Element Replacement
Wat je nodig hebt
  1. Revlon 473 Heating Element Replacement, Shell: stap 1, afbeelding 1 van 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: stap 2, afbeelding 1 van 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: stap 3, afbeelding 1 van 3 Revlon 473 Heating Element Replacement: stap 3, afbeelding 2 van 3 Revlon 473 Heating Element Replacement: stap 3, afbeelding 3 van 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: stap 4, afbeelding 1 van 1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: stap 5, afbeelding 1 van 1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
Conclusie
Jessica Leyva
143 Reputatie
5 handleidingen geschreven
Cal Poly, Team 1-5, Propen Fall 2012 Lid van Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,866
