Ga door naar hoofdinhoud
Revising the brewing unit of Nivona Caferomatica
Wat je nodig hebt
    1. Revising the brewing unit of Nivona Caferomatica, Brewing Unit maintenance: stap 1, afbeelding 1 van 1
      • Remove the brewing unit from the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Revising the brewing unit of Nivona Caferomatica: stap 2, afbeelding 1 van 1
      • Take off the cap covering the screwhole in one corner. The cap ensures a better fit of the brewing unit.
      • Note: some versions of the brewing unit do not have this cap.
      Vraag FixBot
      Voeg opmerking toe
    3. Revising the brewing unit of Nivona Caferomatica: stap 3, afbeelding 1 van 1
      • Remove the single black Torx T10 screw fixing the opening handle.
      • Using a certain amount of force pull the opening handle out of the guidance near the red button.
      • Rotate the handle 90 degrees counterclockwise, then lift it off.
      Vraag FixBot
      Voeg opmerking toe
    4. Revising the brewing unit of Nivona Caferomatica: stap 4, afbeelding 1 van 2 Revising the brewing unit of Nivona Caferomatica: stap 4, afbeelding 2 van 2
      • Unclip the upper protection panel, then remove it by lifting it up.
      Vraag FixBot
      Voeg opmerking toe
    5. Revising the brewing unit of Nivona Caferomatica: stap 5, afbeelding 1 van 1
      • Remove six Torx T15 screws holding together the brewing unit. The screwholes are rather deep.
      • Lift the upper half of the brewing unit up.
      Vraag FixBot
      Voeg opmerking toe
    6. Revising the brewing unit of Nivona Caferomatica: stap 6, afbeelding 1 van 2 Revising the brewing unit of Nivona Caferomatica: stap 6, afbeelding 2 van 2
      • The inside of the brewing unit ist exposed. You can see:
      • The upper piston and its gasket.
      • The funnel for the coffee grounds
      • The lower piston.
      • The hold-down clamp
      Vraag FixBot
      Voeg opmerking toe
    7. Revising the brewing unit of Nivona Caferomatica: stap 7, afbeelding 1 van 3 Revising the brewing unit of Nivona Caferomatica: stap 7, afbeelding 2 van 3 Revising the brewing unit of Nivona Caferomatica: stap 7, afbeelding 3 van 3
      • Remove the funnel.
      • Rotate the lower piston counterclockwise and lift it off.
      • Lift off the upper piston. There ist still a hose connecting the piston to the coffee outlet. In top there ist also the downholder of the brewing unit.
      • Sometimes this downholder ist torn and the coffee leaks out of the brewing unit and does not fill your cup. Inspect the downholder for cracks. You can fix this using a special repair kit.
      Vraag FixBot
      Voeg opmerking toe
    8. Revising the brewing unit of Nivona Caferomatica: stap 8, afbeelding 1 van 3 Revising the brewing unit of Nivona Caferomatica: stap 8, afbeelding 2 van 3 Revising the brewing unit of Nivona Caferomatica: stap 8, afbeelding 3 van 3
      • Remove the hose connecting the upper piston and the coffee outlet.
      • Remove the upper piston.
      • Remove the Torx T10 screw from the screen of the upper piston.
      • Take off the cover of the gasket and the gasket.
      • Replace the gaskets of the upper piston, the coffee outlet and water connector.
      • The lip of the piston gasket must point towards the pressure, i.e. downwards.
      • Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
      Vraag FixBot
      Voeg opmerking toe
    9. Revising the brewing unit of Nivona Caferomatica: stap 9, afbeelding 1 van 1
      • The crema-valve is located in the interior of the upper piston. It is fixed by two Torx T10 screws.
      • Remove both screws. Lift off the valve. Inspect it and clean it.
      • Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult.
      • Lubricate all sliding parts with food-proof silicone grease. Verify the smooth operating of the brewing unit.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Apply all steps in reverse order to re-assemble the device.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
VauWeh
339.975 Reputatie
313 handleidingen geschreven
1Gids Commentaar
Hello all. I have a Nivona 572 cafearomatica and when i press the start button the pump
Does not stop in it goes wild. Any toughts?
Florin Pop Piglesan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 224
Altijd: 14,832
