Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With the controller on its face, remove the five 6 mm Phillips #1 screws.
After removing the screws, carefully lift the controller casing .
Pinch the top and bottom of the shoulder buttons and lift them out.
Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
Carefully lift the circuit board from the controller case.
