Ga door naar hoofdinhoud
Retro-Bit Retro Duo Cartridge Doors Replacement
Wat je nodig hebt
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: stap 1, afbeelding 1 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: stap 1, afbeelding 2 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: stap 1, afbeelding 3 van 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: stap 2, afbeelding 1 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 2, afbeelding 2 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 2, afbeelding 3 van 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: stap 3, afbeelding 1 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 3, afbeelding 2 van 3 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 3, afbeelding 3 van 3
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: stap 4, afbeelding 1 van 2 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 4, afbeelding 2 van 2
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: stap 5, afbeelding 1 van 2 Retro-Bit Retro Duo Cartridge Doors Replacement: stap 5, afbeelding 2 van 2
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
Conclusie
Truong Vo
320 Reputatie
3 handleidingen geschreven
USF Tampa, Team S4-G4, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 528
