Ga door naar hoofdinhoud
Restroom Sink Replacement
Wat je nodig hebt
  1. Restroom Sink Replacement, Restroom Sink: stap 1, afbeelding 1 van 3 Restroom Sink Replacement, Restroom Sink: stap 1, afbeelding 2 van 3 Restroom Sink Replacement, Restroom Sink: stap 1, afbeelding 3 van 3
    • Turn off the water source beneath the sink.
    • If the sink is a bit old or rusted, make sure to wipe it with wipes and paper towels.
    • Wear Gloves for better grip of knobs and to prevent spills over your hand or arm.
  2. Restroom Sink Replacement: stap 2, afbeelding 1 van 3 Restroom Sink Replacement: stap 2, afbeelding 2 van 3 Restroom Sink Replacement: stap 2, afbeelding 3 van 3
    • Turn on the knobs on the sink to confirm the water is off and release the remaining water.
    • Always have a container ready when checking for remaining water to catch in.
    • Once you are finished reassuring, you can move onto step 3.
  3. Restroom Sink Replacement: stap 3, afbeelding 1 van 3 Restroom Sink Replacement: stap 3, afbeelding 2 van 3 Restroom Sink Replacement: stap 3, afbeelding 3 van 3
    • Gently loosen the elbow that connects the sink to the pipe leading to the wall with pliers.
    • Use a container to catch any water in the elbow.
    • Don't use too much strength to avoid damage to the wall pipping as you loosen the elbow.
  4. Restroom Sink Replacement: stap 4, afbeelding 1 van 3 Restroom Sink Replacement: stap 4, afbeelding 2 van 3 Restroom Sink Replacement: stap 4, afbeelding 3 van 3
    • With a sharp blade, cut along the old silicon to detach the sink from the cabinet.
    • Use blase with caution to avoid injury to self or damage to the sink.
    • Then detach the hoses from below the sink.
    • Beware, water might be in the hoses as you detach them.
  5. Restroom Sink Replacement: stap 5, afbeelding 1 van 3 Restroom Sink Replacement: stap 5, afbeelding 2 van 3 Restroom Sink Replacement: stap 5, afbeelding 3 van 3
    • When you are done with steps 1 through 4, remove the old sink and replace it with the new one.
    • If your new sink is a newer model, make sure it has the same length and width with a measuring tape.
    • Beware to avoid damage to the sink or cabinet, if it is placed by force.
  6. Restroom Sink Replacement: stap 6, afbeelding 1 van 3 Restroom Sink Replacement: stap 6, afbeelding 2 van 3 Restroom Sink Replacement: stap 6, afbeelding 3 van 3
    • Reconnect the hoses and turn on the water with the knobs under the sink, to make sure it runs smoothly.
    • Apply silicon to seal areas around sink and let it dry.
    • Wait for the silicon to dry before using it.
Conclusie
To conclude, replacing a sink seems like a tedious job. But, any beginner can do it without a plumber's assistance. Therefore, saving lots of money on labor.
Robertcastillo
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 145
