Ga door naar hoofdinhoud
Respironics REMstar Plus M Series Power Supply Circuit board Replacement
Wat je nodig hebt
  1. Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: stap 1, afbeelding 1 van 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: stap 1, afbeelding 2 van 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: stap 1, afbeelding 3 van 3
    • Place the device face down.
    • Use a T15 Torx screwdriver to remove the six screws in the base plate.
    • Lift the base plate off of the device.
  2. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: stap 2, afbeelding 1 van 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: stap 2, afbeelding 2 van 3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: stap 2, afbeelding 3 van 3
    • Flip the circuit board over to the right.
    • Gently pull the ribbon cable outward to disconnect it from the circuit board.
  3. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: stap 3, afbeelding 1 van 2 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
    • Remove the circuit board.
Conclusie
2 opmerkingen
My unit stops working in the middle of the night, then beeps, & blue light flashes. Will replacing this board fix this, and where can I get one?
mert454 - Antwoord
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
David Edes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 983
