Inleiding
Use this guide to replace a faulty gas cylinder in your Respawn RSP-110 Gaming Chair.
Gas cylinders adjust the seat height in wheeled office and gaming chairs to the user's desired level. However, these chairs may sink over time and not remain at the same level. If you notice your chair not maintaining its height, you can replace its gas cylinder.
Since this process requires using a mallet, take special care not to hurt yourself.
Wat je nodig hebt
Below the seat, push the lift lever up to extend the chair to its full capacity.
To the left of the lift lever, push the lock lever up to ensure the backrest is vertical.
You've successfully replaced the gas cylinder on your chair!
