Ga door naar hoofdinhoud
Respawn RSP-110 Gaming Chair Gas Cylinder Replacement
Wat je nodig hebt
  1. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement, Gas Cylinder: stap 1, afbeelding 1 van 1
    • Below the seat, push the lift lever up to extend the chair to its full capacity.
    • To the left of the lift lever, push the lock lever up to ensure the backrest is vertical.
  2. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 2, afbeelding 1 van 2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 2, afbeelding 2 van 2
    • Lay the chair horizontally with its legs in their open position.
  3. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 3, afbeelding 1 van 2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 3, afbeelding 2 van 2
    • Optional: Place a towel over the bottom end of the cylinder to avoid damaging it in the next step.
  4. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 4, afbeelding 1 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 4, afbeelding 2 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 4, afbeelding 3 van 3
    • Use rubber mallet to strike the bottom of the cylinder firmly to dislodge it.
    • If the cylinder remains lodged, continue striking it with the rubber mallet until it dislodges.
    • Exercise caution to prevent damage and avoid injury while dislodging the cylinder.
  5. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 5, afbeelding 1 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 5, afbeelding 2 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 5, afbeelding 3 van 3
    • Using the pipe wrench/vise-grip, twist the cylinder out of place.
    • You will need to twist clockwise or counter-clockwise repeatedly until the cylinder releases.
  6. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 6, afbeelding 1 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 6, afbeelding 2 van 3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 6, afbeelding 3 van 3
    • Get your new gas cylinder.
    • Make sure that the plastic cylinder cover is around the cylinder.
    • Attach the cylinder to the underside of the seat, and twist counterclockwise.
  7. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 7, afbeelding 1 van 2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 7, afbeelding 2 van 2
    • Place the bottom of the cylinder into the chair base and twist to lock it just enough to safely stand it upright
    • If the cylinder is not secure enough, the chair may fall apart.
  8. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: stap 8, afbeelding 1 van 1
    • Stand the chair upright.
    • Place your knee on the seat and hold the armrests.
    • Apply pressure on the middle of the seat to ensure that the cylinder is locked in place.
Conclusie
You've successfully replaced the gas cylinder on your chair!
Luca Caniglia
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-4, Morris Spring 2024 Lid van UC Davis, Team 2-4, Morris Spring 2024
UCD-MORRIS-S24S2G4
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 69
Altijd: 132
