Ga door naar hoofdinhoud
Rescue Your UGGs: A Guide to Removing Water Stains on UGGs
Wat je nodig hebt
  1. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: stap 1, afbeelding 1 van 2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: stap 1, afbeelding 2 van 2
    • Gently brush the exterior of the boots with a soft suede brush. 
  2. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: stap 2, afbeelding 1 van 2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: stap 2, afbeelding 2 van 2
    • Use the sponge to lightly dampen the outer surface of your boots with cold water (do NOT soak as it will damage fabric).
  3. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: stap 3, afbeelding 1 van 2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: stap 3, afbeelding 2 van 2
    • Apply a small amount of the sheepskin cleaner and conditioner on a wet sponge and gently rub the problem areas on the exterior of the UGG boots. ​ Note: Scrubbing vigorously can cause damage
  4. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: stap 4, afbeelding 1 van 2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: stap 4, afbeelding 2 van 2
    • Stuff newspaper or paper towels into the boots to help maintain their shape. 
  5. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Air Dry: stap 5, afbeelding 1 van 1
    • Place the UGG boots in a dry and well-ventilated area away from direct sunlight to dry (Do not use heat to speed up the process).
  6. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: stap 6, afbeelding 1 van 2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: stap 6, afbeelding 2 van 2
    • When the boots are dry gently brush the exterior with a soft suede brush.  
  7. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: stap 7, afbeelding 1 van 3 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: stap 7, afbeelding 2 van 3 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: stap 7, afbeelding 3 van 3
    • Remove the newspaper or paper towels from the boots.
Eindstreep
Lara Van Heerden
145 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 277
Altijd: 2,593
