Ga door naar hoofdinhoud
ResMed S9 VPAP Auto Inner and Outer Filters Replacement
Wat je nodig hebt
  1. ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: stap 1, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: stap 1, afbeelding 2 van 2
    • Lift up on the lip of the translucent plastic filter cover on the bottom of the device.
    • Peel back the old filter and replace it with the new one.
  2. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 2, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 2, afbeelding 2 van 2
    • To access the internal filter of the ResMed S9 VPAP Auto, flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2 mm Torx T3.
  3. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 3, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to pry off the back panel.
  4. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 4, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 4, afbeelding 2 van 2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove to expose the control panel.
  5. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 5, afbeelding 1 van 1
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
  6. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 6, afbeelding 1 van 3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 6, afbeelding 2 van 3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the plug connecting the red, orange, and black wires to the circuit board.
    • The plug in the top right corner is accessed through the bottom of the device.
    • Flip the circuit board upside down and use the tweezers to squeeze the plastic release underneath the remaining plug.
    • The circuit board will then lift right off, exposing the interior of the machine.
  7. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 7, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 7, afbeelding 2 van 2
    • Remove the five screws from the frame with a T3 Torx screwdriver.
    • Lift off the plastic frame to expose the filter housing.
  8. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 8, afbeelding 1 van 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: stap 8, afbeelding 2 van 2
    • Remove the silicone and the blower to expose the filters.
    • Remove and replace the foam filters.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
where can I purchase the foam filters?
Francis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 907
