Inleiding
Ga naar stap 1 ↓Over time the rubber seal on the air outlet elbow of the ResMed AirSense 10 medical ventilator will wear and cause small air leaks. If the hose and mask are verified to be not leaking, the leak can be located on the air outlet elbow. Check the air outlet elbow when trouble shooting leakages and replace as needed.
Wat je nodig hebt
Position the ResMed Airsense 10 with the water reservoir facing towards you.
Remove the ResMed water tank.
7 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Thanks for showing us how to replace the air outlet elbow. How about showing us the other rubber thingy. Having trouble trying to find them to buy new replacment ones. Thanks
