Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the top of the zipper on the side with the slider.
Peel back any fabric that is covering the zipper stop.
Carefully remove any remaining pieces of the stop using tweezers.
Slide the damaged zipper slider up and off of the zipper.
Grab a new zipper stop.
Insert the teeth into the webbing in the same place where the old stop was located.
Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
Crimp the stop into place.
19 andere personen hebben deze handleiding voltooid.
11 opmerkingen
Where do I get the zipper stop????
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
Great now how ! thank’s :)
