Inleiding
When a zipper pull breaks, or the slider simply wears out, you don’t need to replace the entire zipper. Just replace the zipper slider. This is a quick repair that can make the difference between a zipper that doesn’t work at all and one that works like it’s brand new. Determine the size of your replacement slider by looking on the bottom of your existing slider.
For replacement parts or further assistance, contact Patagonia Customer Service.
Wat je nodig hebt
Video overzicht
Locate the top of the zipper on the side with the slider.
Peel back any fabric that is covering the zipper stop.
Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
Crimp the stop into place.
Comment déterminer la taille de curseur ? Où peut-on acheter un nouveau curseur. Merci pour votre réponse.
Hi Danka, Call Patagonia Customer Service for the specific Slider type and size you need including the zipper stop. 1-800-638-6464.
If ok photo shown closedly to the zipper.tq fyi..
19 andere personen hebben deze handleiding voltooid.
11 opmerkingen
Where do I get the zipper stop????
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
Great now how ! thank’s :)
Oh my goodness, thank you so much! You saved me during the pandemic. Super clear instructions, even though I had a metal zipper and cotton sweatshirt. Patagonia sent me more than all the parts I needed. Thank you again!
How do I get spare parts, zipper slider and stopper?
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
