Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
When a zipper pull breaks, or the slider simply wears out, you don’t need to replace the entire zipper. Just replace the zipper slider. This is a quick repair that can make the difference between a zipper that doesn’t work at all and one that works like it’s brand new. Determine the size of your replacement slider by looking on the bottom of your existing slider.
For replacement parts or further assistance, contact Patagonia Customer Service.
Onderdelen
Geen onderdelen opgegeven.
Video overzicht
  1. Locate the top of the zipper on the side with the slider. Peel back any fabric that is covering the zipper stop. Peel back any fabric that is covering the zipper stop.
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Use end nippers to cut the stop. Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Carefully remove any remaining pieces of the stop using tweezers.
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  5. Slide the damaged zipper slider up and off of the zipper. Slide the damaged zipper slider up and off of the zipper. Slide the damaged zipper slider up and off of the zipper.
    • Slide the damaged zipper slider up and off of the zipper.
  6. Slide the replacement slider onto the zipper. You may need to tug a little to get it past where the old stop was.
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  7. Grab a new zipper stop. Insert the teeth into the webbing in the same place where the old stop was located.
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  8. Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing. Crimp the stop into place. Crimp the stop into place.
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
Eindstreep
16 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
84.440 Reputatie
132 handleidingen geschreven
Where do I get the zipper stop????
Jason Heimink - Antwoord
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Antwoord
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Antwoord
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Antwoord
Great now how ! thank’s :)
Robert Fyfe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 422
Altijd: 78,391
