Inleiding
Not even a screw is required to change the bios battery.
By replacing the CMOS battery the setting will be erased and set by default, in case of problems with the bios its common practice to remove and reinsert the battery to reset it.
Wat je nodig hebt
Aanbevolen document
Press on the clip (in red) and the battery should come out by itself
Insert the new battery
By replacing the CMOS battery the settings should remain saved
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
