Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Get your new zipper pull and position it with the pull-tab down.
Lift up the zipper, as if you were pulling the zipper closed.
Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally.
Pull the zipper pull through the smaller hole.
Rest the zipper back in its normal, hanging position.
Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper.
Bring the zipper pull-tab through the loop.
Pull the zipper pull-tab snug.
The zipper pull should now be inserted and lay flat.
4 andere personen hebben deze handleiding voltooid.
