Ga door naar hoofdinhoud
Replacing a Sprinkler Extension
Wat je nodig hebt
  1. Replacing a Sprinkler Extension, Sprinkler Extension: stap 1, afbeelding 1 van 1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: stap 2, afbeelding 1 van 1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: stap 3, afbeelding 1 van 1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: stap 4, afbeelding 1 van 2 Replacing a Sprinkler Extension: stap 4, afbeelding 2 van 2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: stap 5, afbeelding 1 van 1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: stap 6, afbeelding 1 van 2 Replacing a Sprinkler Extension: stap 6, afbeelding 2 van 2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
Conclusie
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
111 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 801
