Ga door naar hoofdinhoud
Replacing VuPoint DC-ST210-VP View Finder
Wat je nodig hebt
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: stap 1, afbeelding 1 van 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: stap 2, afbeelding 1 van 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: stap 2, afbeelding 2 van 3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: stap 2, afbeelding 3 van 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: stap 3, afbeelding 1 van 2 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: stap 3, afbeelding 2 van 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
Conclusie
Dorey Chiu
1 Reputatie
1 Handleiding geschreven
Baylor, Team 8-15, Williams Fall 2014 Lid van Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 526
