Ga door naar hoofdinhoud
Replacing Tungsten E screen. PAL5037
Wat je nodig hebt
    1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: stap 1, afbeelding 1 van 2 Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: stap 1, afbeelding 2 van 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Tungsten E screen. PAL5037: stap 2, afbeelding 1 van 3 Replacing Tungsten E screen. PAL5037: stap 2, afbeelding 2 van 3 Replacing Tungsten E screen. PAL5037: stap 2, afbeelding 3 van 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing Tungsten E screen. PAL5037: stap 3, afbeelding 1 van 2 Replacing Tungsten E screen. PAL5037: stap 3, afbeelding 2 van 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Replacing Tungsten E screen. PAL5037: stap 4, afbeelding 1 van 2 Replacing Tungsten E screen. PAL5037: stap 4, afbeelding 2 van 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Vraag FixBot
      Voeg opmerking toe
    5. Replacing Tungsten E screen. PAL5037: stap 5, afbeelding 1 van 3 Replacing Tungsten E screen. PAL5037: stap 5, afbeelding 2 van 3 Replacing Tungsten E screen. PAL5037: stap 5, afbeelding 3 van 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Vraag FixBot
      Voeg opmerking toe
    6. Replacing Tungsten E screen. PAL5037: stap 6, afbeelding 1 van 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Tungsten E screen. PAL5037, Replacing Touch screen: stap 7, afbeelding 1 van 1
      • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
      • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
      • Be careful not to damage the flex connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kevin Hom
118 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-22, Maness Winter 2010 Lid van Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 5,931
