Ga door naar hoofdinhoud
Snapfon ez One Motherboard Replacement
Wat je nodig hebt
  1. Snapfon ez One Motherboard Replacement, Remove the battery cover: stap 1, afbeelding 1 van 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Motherboard Replacement, Remove the battery: stap 2, afbeelding 1 van 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Motherboard Replacement, Removing the plastic inserts: stap 3, afbeelding 1 van 2 Snapfon ez One Motherboard Replacement, Removing the plastic inserts: stap 3, afbeelding 2 van 2
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Motherboard Replacement, Remove the shield screws: stap 4, afbeelding 1 van 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: stap 4, afbeelding 2 van 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: stap 4, afbeelding 3 van 3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Motherboard Replacement, Separate the case: stap 5, afbeelding 1 van 3 Snapfon ez One Motherboard Replacement, Separate the case: stap 5, afbeelding 2 van 3 Snapfon ez One Motherboard Replacement, Separate the case: stap 5, afbeelding 3 van 3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Motherboard Replacement, Remove the volume slider: stap 6, afbeelding 1 van 1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Motherboard Replacement, Remove the motherboard: stap 7, afbeelding 1 van 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: stap 7, afbeelding 2 van 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: stap 7, afbeelding 3 van 3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
Conclusie
John Bender
818 Reputatie
8 handleidingen geschreven
Clemson, Team 6-5, Benson Spring 2014 Lid van Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 10
Altijd: 214
