Ga door naar hoofdinhoud
Replacing Samsung Galaxy S4 SIM Card
Wat je nodig hebt
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: stap 1, afbeelding 1 van 2 Replacing Samsung Galaxy S4 SIM Card, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Antwoord
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Antwoord
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    it worked for me
    John Donovan - Antwoord
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Antwoord
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Antwoord
Conclusie
78 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.783 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
3 opmerkingen
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Antwoord
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Antwoord
Removing sim card tray?
G M Chadwick - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 309
Altijd: 245,773
