Ga door naar hoofdinhoud
Replacing Samsung Galaxy S4 SIM Card
Wat je nodig hebt
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: stap 1, afbeelding 1 van 2 Replacing Samsung Galaxy S4 SIM Card, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card: stap 2, afbeelding 3 van 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: stap 3, afbeelding 3 van 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, Battery: stap 4, afbeelding 3 van 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 1 van 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 2 van 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
Conclusie
78 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.936 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.277 handleidingen geschreven
3 opmerkingen
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Antwoord
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Antwoord
Removing sim card tray?
G M Chadwick - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 319
Altijd: 245,882
