Inleiding
It is fairly simple to replace the bread lift shelf, even though the metal flaps holding the bread lift shelf can be difficult to access.
Wat je nodig hebt
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Use a flat-head screwdriver to separate the metal flap from the metal plate.
Bijna klaar!
Conclusie
