Ga door naar hoofdinhoud
Replacing Oster 6329 Bread Lift Shelf
Wat je nodig hebt
  1. Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: stap 1, afbeelding 1 van 2 Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: stap 1, afbeelding 2 van 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Replacing Oster 6329 Bread Lift Shelf: stap 2, afbeelding 1 van 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Replacing Oster 6329 Bread Lift Shelf: stap 3, afbeelding 1 van 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Replacing Oster 6329 Bread Lift Shelf: stap 4, afbeelding 1 van 2 Replacing Oster 6329 Bread Lift Shelf: stap 4, afbeelding 2 van 2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Replacing Oster 6329 Bread Lift Shelf: stap 5, afbeelding 1 van 2 Replacing Oster 6329 Bread Lift Shelf: stap 5, afbeelding 2 van 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Replacing Oster 6329 Bread Lift Shelf, Bread Lift Shelf: stap 6, afbeelding 1 van 1
    • Use a flat-head screwdriver to separate the metal flap from the metal plate.
  7. Replacing Oster 6329 Bread Lift Shelf: stap 7, afbeelding 1 van 2 Replacing Oster 6329 Bread Lift Shelf: stap 7, afbeelding 2 van 2
    • Grasp the metal flap with the large needle nose pliers.
    • Unbend metal flap until at a 90 degree angle from the metal plate.
    • Repeat these steps for the second metal flap.
  8. Replacing Oster 6329 Bread Lift Shelf: stap 8, afbeelding 1 van 1
    • Use the large need nose pliers to grab the metal panel.
    • Pull the metal panel away from the body of the toaster to dislodge the flaps.
  9. Replacing Oster 6329 Bread Lift Shelf: stap 9, afbeelding 1 van 2 Replacing Oster 6329 Bread Lift Shelf: stap 9, afbeelding 2 van 2
    • Push the metal flaps towards the body of the toaster to access the bread lift shelf.
  10. Replacing Oster 6329 Bread Lift Shelf: stap 10, afbeelding 1 van 1
    • Push down on the opposite side of the bread lift shelf to expose the metal flaps.
  11. Replacing Oster 6329 Bread Lift Shelf: stap 11, afbeelding 1 van 1
    • Pull up on the bread lift shelf to remove from the toaster.
Conclusie
Jason Yoon
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-15, Regan Winter 2014 Lid van Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 610
