Ga door naar hoofdinhoud
Replacing Nokia Classic 2600c-2b Faceplate
Wat je nodig hebt
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: stap 1, afbeelding 1 van 2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: stap 1, afbeelding 2 van 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: stap 2, afbeelding 1 van 1
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: stap 3, afbeelding 1 van 2 Replacing Nokia Classic 2600c-2b Faceplate: stap 3, afbeelding 2 van 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: stap 4, afbeelding 1 van 2 Replacing Nokia Classic 2600c-2b Faceplate: stap 4, afbeelding 2 van 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: stap 5, afbeelding 1 van 1
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: stap 6, afbeelding 1 van 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
Conclusie
Ian VanZandt
654 Reputatie
5 handleidingen geschreven
James Madison, Team 3-1, Klein Spring 2012 Lid van James Madison, Team 3-1, Klein Spring 2012
JMU-KLEIN-S12S3G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 396
