Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the battery release latch to the right.
Pull out the battery out towards the front of the device.
Remove the 7 mm Phillips #0 screws.
Remove the 10 mm Phillips #0 screws.
Remove the 14 mm Phillips #0 screw.
Insert the plastic opening tools between the right and left sides of the latch.
Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
Insert the plastic opening tools towards the right side of the latch.
Gently pry the right side out to release the top cover.
Use your fingers or a spudger to detach the connector.
Slowly and carefully lift the speaker with your fingers.
Use your fingers to unplug the wires from the connector.
Één andere persoon heeft deze handleiding voltooid.
