Ga door naar hoofdinhoud
Replacing Crosley CR42 Needle
Wat je nodig hebt
  1. Replacing Crosley CR42 Needle, Needle: stap 1, afbeelding 1 van 2 Replacing Crosley CR42 Needle, Needle: stap 1, afbeelding 2 van 2
    • The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
  2. Replacing Crosley CR42 Needle: stap 2, afbeelding 1 van 2 Replacing Crosley CR42 Needle: stap 2, afbeelding 2 van 2
    • While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
    • The needle should hang, as shown.
  3. Replacing Crosley CR42 Needle: stap 3, afbeelding 1 van 2 Replacing Crosley CR42 Needle: stap 3, afbeelding 2 van 2
    • Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
    • WHEN ATTACHING NEW NEEDLE: Slide the back (open U shaped side) of the needle on first, then press to snap the front into place. You should hear a click.
Conclusie
Roberto Rosila
319 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-38, Maness Winter 2014 Lid van Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Leden
5 handleidingen geschreven
Één opmerking
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
thmccullough - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 5,136
