Ga door naar hoofdinhoud
Replacing Creative Zen X-Fi Midsection Plate
Wat je nodig hebt
  1. Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: stap 1, afbeelding 1 van 3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: stap 1, afbeelding 2 van 3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: stap 1, afbeelding 3 van 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Midsection Plate, Rubber Button Cover: stap 2, afbeelding 1 van 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip Part 1: stap 3, afbeelding 1 van 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip: stap 4, afbeelding 1 van 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Midsection Plate, Access Midsection Plate: stap 5, afbeelding 1 van 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below Button Chip: stap 6, afbeelding 1 van 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below LCD Screen: stap 7, afbeelding 1 van 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
Conclusie
Westley Courchene
3.389 Reputatie
14 handleidingen geschreven
USF Tampa, Team 1-1, Remmell Fall 2015 Lid van USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 156
