Ga door naar hoofdinhoud
Replacing Creative Zen X-Fi Button Input Chip Part 1
Wat je nodig hebt
  1. Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: stap 1, afbeelding 1 van 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: stap 1, afbeelding 2 van 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: stap 1, afbeelding 3 van 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Button Input Chip Part 1, Rubber Button Cover: stap 2, afbeelding 1 van 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip Part 1: stap 3, afbeelding 1 van 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip: stap 4, afbeelding 1 van 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
Conclusie
Westley Courchene
3.410 Reputatie
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 419
