Ga door naar hoofdinhoud
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
Wat je nodig hebt
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: stap 1, afbeelding 1 van 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 2, afbeelding 1 van 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 2, afbeelding 2 van 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 2, afbeelding 3 van 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 3, afbeelding 1 van 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 3, afbeelding 2 van 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 4, afbeelding 1 van 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 4, afbeelding 2 van 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 5, afbeelding 1 van 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 5, afbeelding 2 van 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 6, afbeelding 1 van 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: stap 6, afbeelding 2 van 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 57
Altijd: 3,917
