Ga door naar hoofdinhoud
Replacing Coffee Spout Manifold on Nivona Caferomatica 770
Wat je nodig hebt
    1. Replacing Coffee Spout Manifold on Nivona Caferomatica 770, Coffee Spout Manifold: stap 1, afbeelding 1 van 2 Replacing Coffee Spout Manifold on Nivona Caferomatica 770, Coffee Spout Manifold: stap 1, afbeelding 2 van 2
      • Remove the plastic plate with the 'Nivona' label carefully with a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 2, afbeelding 1 van 1
      • Behind it, you'll find a chrome bezel. It is mounted at the marked spots.
      • Push the mounting points with a plastic opening tool to the side and remove the bezel carefully.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 3, afbeelding 1 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 3, afbeelding 2 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 3, afbeelding 3 van 3
      • Remove the LEDs of the cup lighting from their holding clips and bend them aside.
      • Leverage the holder of the lighting element off and remove it.
      Vraag FixBot
      Voeg opmerking toe
    4. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 4, afbeelding 1 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 4, afbeelding 2 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 4, afbeelding 3 van 3
      • Now it is possible to remove the keypad with the display, it is only held by clips. Remove it carefully by hand.
      • The keypad is connected by a large wire harness to the machine. The wire harness won't be removed, the keypad will only be pushed out of the way.
      Vraag FixBot
      Voeg opmerking toe
    5. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 5, afbeelding 1 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 5, afbeelding 2 van 3 Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 5, afbeelding 3 van 3
      • Now the spout is easily accessible. It is only fixed in place by clips and can be removed via a flat screwdriver or spatula.
      • The spout is now only connected to the coffee hose made of silicone.
      Vraag FixBot
      Voeg opmerking toe
    6. Replacing Coffee Spout Manifold on Nivona Caferomatica 770: stap 6, afbeelding 1 van 1
      • Pull the silicone hose off the coffee spout.
      • The coffee spout is disconnected.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repeat the steps in reverse order to reassemble the device.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
VauWeh
339.975 Reputatie
313 handleidingen geschreven
3Gids Commentaar
Toll beschrieben mit super Fotos.
Einfach sich Gedanken gemacht wie man es Schritt für Schritt es einem mitteilen kann wie es gemacht wird.
Super!
Gruß
Thomas
t.ohl - Antwoord Deel
Super genaue Schritt für Schritt Anleitung und Fotos.
Einfach! toll
Gruß
Thomas
Freut mich, wenn es nützt.
VauWeh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 115
Altijd: 10,469
