Ga door naar hoofdinhoud
Replacing Atari Lynx Buttons and D-Pad
Wat je nodig hebt
  1. Replacing Atari Lynx Buttons and D-Pad, Atari Lynx: stap 1, afbeelding 1 van 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Buttons and D-Pad: stap 2, afbeelding 1 van 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Buttons and D-Pad: stap 3, afbeelding 1 van 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Buttons and D-Pad: stap 4, afbeelding 1 van 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Buttons and D-Pad, Buttons and D-Pad: stap 5, afbeelding 1 van 1
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from the front panel of Atari.
  6. Replacing Atari Lynx Buttons and D-Pad: stap 6, afbeelding 1 van 2 Replacing Atari Lynx Buttons and D-Pad: stap 6, afbeelding 2 van 2
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
Conclusie
Tyler Williams
354 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-42, Maness Winter 2014 Lid van Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Leden
16 handleidingen geschreven
1Gids Commentaar
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 2,475
