Ga door naar hoofdinhoud
Replacement of fans on the Dell XPS 13 9380
Wat je nodig hebt
  1. Replacement of fans on the Dell XPS 13 9380, Remove the back panel: stap 1, afbeelding 1 van 3 Replacement of fans on the Dell XPS 13 9380, Remove the back panel: stap 1, afbeelding 2 van 3 Replacement of fans on the Dell XPS 13 9380, Remove the back panel: stap 1, afbeelding 3 van 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of fans on the Dell XPS 13 9380, Remove the battery: stap 2, afbeelding 1 van 2 Replacement of fans on the Dell XPS 13 9380, Remove the battery: stap 2, afbeelding 2 van 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of fans on the Dell XPS 13 9380, Remove the fans: stap 3, afbeelding 1 van 2 Replacement of fans on the Dell XPS 13 9380, Remove the fans: stap 3, afbeelding 2 van 2
    • 1- Remove the screw (M1.6 x 3) that fixes the WiFi card and the cable holder the webcam on the motherboard.
    • 2- Remove the WiFi card and the cable holder for the webcam from the motherboard.
    • 3- Disconnect and lift the webcam cable from the motherboard. You will need to remove the adhesive tape that attaches the cable.
    • 4- Disconnect the power cable from the right fan of the motherboard.
    • 5- Disconnect the power cable from the left fan of the motherboard.
    • 6- Remove the two screws (M1.6 x 3) that attach the fans to the motherboard.
    • 7- Remove the fans from the motherboard.
Conclusie
To reassemble your device, follow the instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Schwarzer helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Schwarzer
5.029 Reputatie
13 handleidingen geschreven
i.Fixit FR Team Lid van i.Fixit FR Team
Community
3 Leden
40 handleidingen geschreven
Één opmerking
I do apologise if this is a redundant question. Would the bits included with the IFIXIT Essential Toolkit be sufficient to proceed with this operation, or is a more extensive kit like the Mako used here be a necessity? Thanks for the help!
Gabriele C. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 55
Altijd: 3,525
