Ga door naar hoofdinhoud
Replace HP Z820 GPU.
  1. Replace HP Z820 GPU., Opening the PC case: stap 1, afbeelding 1 van 2 Replace HP Z820 GPU., Opening the PC case: stap 1, afbeelding 2 van 2
    • First, pull the handle and raise the upper part of the case.
    • Make sure that you have unlocked the lock that is located close to the handle.
    • After taking the upper part off, you'll see the covers of the different pieces of the PC.
  2. Replace HP Z820 GPU., Opening the GPU compartment: stap 2, afbeelding 1 van 3 Replace HP Z820 GPU., Opening the GPU compartment: stap 2, afbeelding 2 van 3 Replace HP Z820 GPU., Opening the GPU compartment: stap 2, afbeelding 3 van 3
    • Raise the cover of the left lower side.
  3. Replace HP Z820 GPU., GPU with guide: stap 3, afbeelding 1 van 1
    • This PC has a full-sized GPU with a guide that fits the GPU in the case. That allows you to avoid physicall damages on the GPU.
    • The GPU has a guide. It's necessary to pay attention and don't forget about it while taking the GPU off.
  4. Replace HP Z820 GPU., GPU Removal, Part 1: stap 4, afbeelding 1 van 2 Replace HP Z820 GPU., GPU Removal, Part 1: stap 4, afbeelding 2 van 2
    • Disconnect the power connector from the GPU.
    • You can clip the connectors in a specifically designed place.
    • Raise the rod that maintains the PCI GPU in place.
  5. Replace HP Z820 GPU., GPU Removal, Part 2: stap 5, afbeelding 1 van 3 Replace HP Z820 GPU., GPU Removal, Part 2: stap 5, afbeelding 2 van 3 Replace HP Z820 GPU., GPU Removal, Part 2: stap 5, afbeelding 3 van 3
    • The first two steps must be performed simultaneously. If you release the tab, it returns to its previous position.
    • Raise the tab that maintains the GPU in its port.
    • Raise the GPU slowly from the side of the guide until the GPU partially comes out of its port.
    • Raise the GPU from its other side.
  6. Replace HP Z820 GPU., Installation using the guide: stap 6, afbeelding 1 van 3 Replace HP Z820 GPU., Installation using the guide: stap 6, afbeelding 2 van 3 Replace HP Z820 GPU., Installation using the guide: stap 6, afbeelding 3 van 3
    • If your GPU has no guide, you can go to the next step.
    • Introduce the new GPU at 45º from the motherboard.
    • Pay attention and avoid damaging the motherboard during the insertion.
    • Place the guide in front of the appropriate slot and push the graphics card into it, making sure it fits into its PCI slot.
    • To check that your graphics card is correctly installed, check that the tab is properly locked in place.
    • Don't forget to connect the power supply cables of the GPU if it's necessary.
  7. Replace HP Z820 GPU., Installation without guide: stap 7, afbeelding 1 van 2 Replace HP Z820 GPU., Installation without guide: stap 7, afbeelding 2 van 2
    • Insert the graphics card into the PCI bracket until it clicks into place.
    • Don't forget to connect the power supply connectors to the GPU if it's necessary.
  8. Replace HP Z820 GPU., Case's particularity: stap 8, afbeelding 1 van 2 Replace HP Z820 GPU., Case's particularity: stap 8, afbeelding 2 van 2
    • The Sapphire RX 5700XT GPU is the largest card that fits in the case without problems.
    • Maximum GPU height: 11cm.
    • As it's already explained, the case has special spots for clipping the unused power supply ports.
Conclusie
The reinstallation stages are included in the tutorial.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Hyperion
1.911 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 666
