Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Left image shows iPhone with missing front dust mesh
Right image shows dust meshes on bottom
Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
Fold the piece of mesh longways using the plastic tip
Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
Put piece of mesh into place using plastic tip
That's it - see the result on the images
28 andere personen hebben deze handleiding voltooid.
Één opmerking
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
