Ga door naar hoofdinhoud
Repairing iPhone 4 dust mesh
Wat je nodig hebt
  1. Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: stap 1, afbeelding 1 van 2 Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: stap 1, afbeelding 2 van 2
    • Left image shows iPhone with missing front dust mesh
    • Right image shows dust meshes on bottom
  2. Repairing iPhone 4 dust mesh: stap 2, afbeelding 1 van 2 Repairing iPhone 4 dust mesh: stap 2, afbeelding 2 van 2
    • Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
    • Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
  3. Repairing iPhone 4 dust mesh: stap 3, afbeelding 1 van 2 Repairing iPhone 4 dust mesh: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Fold the piece of mesh longways using the plastic tip
    • Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
    • Put piece of mesh into place using plastic tip
    • That's it - see the result on the images
Eindstreep
28 andere personen hebben deze handleiding voltooid.
aiwo
2.286 Reputatie
1 Handleiding geschreven
Één opmerking
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
Rene Jeddore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 50,388
