Ga door naar hoofdinhoud
Repairing a Wobbly Piano Bench
Wat je nodig hebt
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: stap 1, afbeelding 1 van 1
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: stap 2, afbeelding 1 van 1
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: stap 3, afbeelding 1 van 3 Repairing a Wobbly Piano Bench: stap 3, afbeelding 2 van 3 Repairing a Wobbly Piano Bench: stap 3, afbeelding 3 van 3
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: stap 4, afbeelding 1 van 3 Repairing a Wobbly Piano Bench: stap 4, afbeelding 2 van 3 Repairing a Wobbly Piano Bench: stap 4, afbeelding 3 van 3
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: stap 5, afbeelding 1 van 1
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: stap 6, afbeelding 1 van 2 Repairing a Wobbly Piano Bench: stap 6, afbeelding 2 van 2
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: stap 7, afbeelding 1 van 2 Repairing a Wobbly Piano Bench: stap 7, afbeelding 2 van 2
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
Conclusie
You can redo this process every 6 months to make sure your bench is always stable.
Één andere persoon heeft deze handleiding voltooid.
Davood Dehghani Firoozabadi
428 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 1,127
