Ga door naar hoofdinhoud
Repairing a Panasonic SA-HT810V with the H02/H07 error
Wat je nodig hebt
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 1, afbeelding 1 van 3 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 1, afbeelding 2 van 3 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 1, afbeelding 3 van 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 2, afbeelding 1 van 2 Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 2, afbeelding 2 van 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 3, afbeelding 1 van 1
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 4, afbeelding 1 van 2 Repairing a Panasonic SA-HT810V with the H02/H07 error: stap 4, afbeelding 2 van 2
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Cheadle
161 Reputatie
7 handleidingen geschreven
Cal Poly, Team 16-5, Maness Spring 2010 Lid van Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Leden
3 opmerkingen
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Antwoord
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Antwoord
Can’t get screws undone on ours… Help!
Matthew - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 55
Altijd: 28,069
