Ga door naar hoofdinhoud
Repairing a Broken or Loose Paper Towel Hanger
Wat je nodig hebt
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: stap 1, afbeelding 1 van 1
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: stap 2, afbeelding 1 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 2, afbeelding 2 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 2, afbeelding 3 van 3
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: stap 3, afbeelding 1 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 3, afbeelding 2 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 3, afbeelding 3 van 3
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: stap 4, afbeelding 1 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 4, afbeelding 2 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 4, afbeelding 3 van 3
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: stap 5, afbeelding 1 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 5, afbeelding 2 van 3 Repairing a Broken or Loose Paper Towel Hanger: stap 5, afbeelding 3 van 3
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
Conclusie
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 134
