Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will help you repair a broken connection from the cable to motherboard.
Wat je nodig hebt
First thing is removing the 20 phillips screws from the back plate. And if you're like me, you'll have to remove your wall mounting bracket as well.
After removing the back plate, you'll see some sweet stuff. We'll be focusing on the motherboard to the right.
2 phillips screws hold down covers over your inputs.
Note this screw holds down both covers overlapping each other.
If you're like us, you notice the bottom cover does not move! 2 small phillips screws need to be removed before continuing.
Once all removed you'll see that there is supposed to be a cable connection where you see a big hole.
You can then proceed to solder your new connection in like we did. If you decide to replace the entire part you'll need to remove the motherboard.... We'll save that for a different thread.
14 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Are there pics of what needs to be done in order to solder the cable connector correctly?
how can I order the part to repair the coax connector for the Vizio 32 inch tv
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
