Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Having problems with your cable connection? Has replacing the cable failed to fix the problem? You may have a broken connection in your motherboard. This guide will help you repair a broken connection from the cable to motherboard.
Wat je nodig hebt
The first thing to do is remove the 20 Phillips screws from the back plate. If you're like me, you'll have to remove your wall mounting bracket as well.
After removing the back plate, you'll see some sweet stuff. We'll be focusing on the motherboard to the right.
2 Phillips screws hold down covers over your inputs.
Note this screw holds down both covers where they overlap.
If you're like me, you'll notice the bottom cover doesn't move! 2 small Phillips screws need to be removed before continuing.
14 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Are there pics of what needs to be done in order to solder the cable connector correctly?
how can I order the part to repair the coax connector for the Vizio 32 inch tv
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
